Bosch Plugs
Aeroking
e.i.
Well, my truck has been running like crap. Go figure. I have replaced just about everything that i can. Cap, Rotor, 8mm wires, Bosch Plat. 2s. My DM files show that my fueling and acceleration and everything is right on.
Under acceleration it runs ok, but when its idleing, or under normal driving conditions, it spits, sputters, clunks, shakes, pops, and i even think i heard it backfire.
I pulled the plugs and they look great, a nice light gray color, they are identical to each other, so all cylinders are firing the same.
I pulled the old set of NGKs out, and put in the Bosch Platinum 2s. But i also changed several other things at that time, so it might be something else.
Does anyone run anything other than NGKs??
Anyone run Bosch Platinums??
I'll pick up some UR5's on my way home from work today.
Tooky
Serious about performance
Re: Bosch Plugs
Try the UR5s. Turbos + Platinum = universally recommended against
Aeroking
e.i.
Re: Bosch Plugs
i put in the UR5s ran smooth once it warmed up. But in open loop it still runs a little rough. I bought a new coil, and another fuel filter. I'll change those and see if i notice any difference.
CLONE
Re: Bosch Plugs
I've had great luck with UR6IX NGK's. The autolite 23's were good. So were the UR5 and UR6 NGK's. CR42ts is always a winner as well.
Aeroking
e.i.
Re: Bosch Plugs
we're close enough, any chance we can meet up so i can see your truck?
