BOV placement pics
sychris
anybody got pics of where you T in or the best place to T into . i got the hard pipe and i dont know where to cut the T in
sychris
Re: BOV placement pics
if you have a hardpipe....
Buy a flange for the bov and weld it
i got the hard pipe the flange is on and bov is on i just need to know where the vaccume line Ts into . the greddy bov came with 2 different size Ts
bundie
RPM sells nice braided brakebooster hoses with a adapter for a boostgauge, i screw an adapter on it so it has 2 vacuum ports.
I wont recommed to T-it into your vaccuum line for your map sensor or FP regulator!
canadian
sy in progress
There's a vacuum line that runs from the front of the intake around the passenger side and to the back of the intake. There should be a line coming off of this going inside the cab for the A/C vents, etc. T into that line for the BOV. Here's a diagram:
bundie
That line wont see boost.
you need a vac line that sees boost i belive
canadian
sy in progress
A blow off valve typically doesn't need to see boost. It's job is to vent the intake charge back into the atmosphere or downpipe so that it doesn't hit the back of the turbo. A wastegate needs to see boost to bleed it off.
Some blow off valves can do both boost and vacuum, but most are vacuum only.
sychris
i have no cruise control and my a/c has been deleted
canadian
sy in progress
I have neither as well, but I still have the line that goes from the front to the rear, in addition to the hard line going into the cab through the firewall to operate the vents. If you have none of this, you can tap into the line going from the brake booster to the upper intake, or as a last resort the line going to the FPR/MAP.
Damian
I thought BOVs were supposed to see both. Boost pressure to help keep the BOV closed under boost conditions since there is equal pressure on both sides of the diaphragm and vacuum to help it open when you let off he throttle. I turboed my Eclipse and ran my BOV the same way and Evo does, right off of the intake manifold. Wastegate diaphragms don't like vacuum at all.
