Bov question
syty9933
i read somewhere that they take away horsepower. i thought they just helped your turbo and helped spool-up. can someone inform me????
SYO237
SyTy Registry
Re: Bov question
They reduce pressure put back on the turbo when you let out of the throttle. Its basically a vent and will stop the compressor wheel/shaft from stalling and still spin freely. It also allows for better spool up again when you get back on the throttle.
I think losing HP would only come from if the BOV is leaking and your not able to gain full boost.
syty9933
Re: Bov question
Aight thats what i thought.... thanks, i think the person was referring to a crappy blow off valve then, not so much in general
TYTILIDIE
METH HEAD
Re: Bov question
Be careful what you buy. I had 2 TurboXS RFL's and they BOTH leaked, out of the box. I would do some research first and go for performance and not so much sound. FWIW, I will going with the Synapse.
syty9933
Re: Bov question
i just won a turbonetics godzilla off ebay for only 112 dollars
