Bow Tie Block oiling and piston cooling....
4C FED
Absolutum Dominium
Just curious about somethings for somewhere down the road.
What makes the oiling system better in a Bow Tie block? How does the oiling system differ from the stock block?
And I have a question about piston cooling using oil jets.
I was checking out this page: http://toyotaperformance.com/pushing.htm
If you look at the very bottom they have a picture of a pistion with an oil jet on it. This is supposed to provide better heat transfer from the piston.
Does anybody know about this or have any thoughts on it? Anyone ever seen turbo/SC pistons like these before?
MikeRenz
not stock
I have a vtec prelude (H22a engine - the same engine that all the lil civic drag racers use)...and that has oil squirters that shoot up from the bottom of each cylinder.
The car also redlines at 7800rpms so I'm wondering if our trucks really need it. How much cooling can that do to fight the harmful detonation? I wouldn't think too much.
4C FED
Absolutum Dominium
Don't know, but if you read that page at the bottom it indicates that the larger the bore size the more important it is.
But why would a high revving, small bore motor benefit from it?
It certainly isn't going to generate more heat than a forced induction motor, right?
And I'm not so sure that the basis for using it is to reduce detonation, but to aid heat transfer, which would result in being able to run more boost or run a little leaner without causing damage.
I don't know, just looking for some opinions. Thought it was interesting.
Anybody have an answer to the Bow Tie question yet?
GOTSWRV
The bowtie has three oil runners through the lifter galley, just like the smallblock. Our stock motor has two, this means one of the two is just for lifters, and the other is shared. I can't rember what it is shared with. It's been a long time since I read that book. But GM says wih the stock oiling 7500RPM safe, they also say the crank can only hold 300HP, so I'd say they were more conservative than honest.
4C FED
Absolutum Dominium
Thanks fo rthat insight.
Now this brings up another questions I have had.
Is there any reason why we wouldn't want to run a high pressure/high volume oil pump?
Everyone always says run a high volume pump, but why not a high volume/high pressure pump?
GOTSWRV
If you don't need it why do it? To get higher pressure you get more pump friction causing more pump wear and pump failure can become a issue. If the pressure is holding the parts apart from each other, then more pressure is only going to create problems. Most of the guys I know with drag cars try to drop as much pressure as they can. this generally is an expensive learning curve they go through to find out how far they can go.
syntax
i was told get a high pressure but not a high volume pump, because it can drain the sump on a 4.3 if its made for a sbc bbc, but like i said i heard it, and could be complete rubish
kbbeckius
Piston oiling
Piston oiling
I pondered this as well several months ago, many engines that were designed as dedecated forced induction (usually turbo) have some provision to oil the backside of the piston. Why? to pull heat out of the piston crown, and reduce detonation, usually manufacturers do it as a manner to increase longevity. While there is no easy method I see to set up an oil jet arrangement, there is another idea which could have roughly the same effect. Forced piston pin oiling, some connecting rod manufacturers offer this as an option (Oliver, Carillo, probably others), the rod has a hole or holes drilled vertically through the beam from the rod journal to the pin journal. If you were to cut a small groove around inside the small end as a oil passage, and a small hole at the top, it should work to oil the backside of the piston. Even if you didn't modify the rod, it would probably splash much more oil up there than stock.
Just a thought,
Brad
myclone
Just a thought on oil pumps.
From ppl Ive spoken to, things Ive read, and finally my own experience Ive found that a high volume pump in a stock sumped 4.3 can drain the pan and suck air. The personal experience was with a NA 4.3 that was turning WAY up there (compared to our RPM range). This was with a STOCK depth 2wd oil pan. I swapped the oil pump out with a reg oil pump but with a stronger LT-1 (old LT-1) bypass spring. I also added 1 inch to the pans sump depth and never had any more oiling probs.
BTW. The oil drain back holes had been opened up in the block AND the inside of the block smoothed to promote quick drain back. Didnt seem to help with the high volume pump and stock depth/capacity pan.
IMO (repeat, OPINION) a stock pump in a syty that is turning less than 6k RPM is fine combined with the steel sleaved pump drive. Maybe even fine for a lil higher but if your getting a syty into much more than ~6.2k then you have abviously got yourself a max effort build and have prepared the oiling system accordingly. Least Id hope so.
From what Ive read the bow tie block has or can be machined for "priority main" oiling. I think this means that center one of the three oil supply galleries that are on either side of the cam is dedicated to supplying oil to the main bearings only. The other two supply their prospective lifter banks.
I believe on the production block that there is only TWO oil supply galleries and one is shared with the mains and one lifter bank. Im going by memory here and could be wrong. Id hafta go dig out the GM perf parts catalog to see. God only knows where thats at now as its not on the back of the toilet anymore. :(
I dunno about the bottom of the piston oil sprayers. A LOT of oil gets flung off the crank/rods and gets thrown up onto the bottom of the piston. I think in all but the most radical builds that it wouldnt really be needed. Its not "cool" oil but neither would oil taken from the internal oiling of the block. Seems to me that it would make any wear on the oil contral rings become amplified as they would now have to keep the extra oil thats up there foating around out of the comb chamber.
I think that some diesel engines use these thuogh but there is a big/huge diff in the RPM that they are used in and for how long they are at WOT/under boost. Ever notice a semi pulling a LONG grade while heavily loaded. Thats an awful long time to be at WOT/boost but the RPM prolly never exceeds ~3k. Not alot or as much oil getting "naturally" flung up onto the bottom of the piston crown there as our 5k RPM engines would. Again, this is just my opinion and I could be wrong (happens from time to time ;) ).
0-60N4
v-8 style oiling
v-8 style oiling
I know Jim Stokes always takes the Bow Tie Blocks and machines the oil passages for "V-8 Style" oiling. All I know is it involvs plugging a hole and drilling some others.
A friend owned a Dash series race team and when they switched from 4 cylinders to 6 cylinders he was using a bow tie block and kept having oil related failures. I got him in contact with Jim Stokes, they did the oiling modification and never had any more problems.
Jim Longwith
GOTSWRV
You guys are on track with the Bowtie oiling info. I got a thought; get your pistons coated. If they reject the more heat, you have less the get rid of. The more heat stays off the piston the more gets send out the exaust. Your turbine will be happy. And your friends will think your cool!! I'm gonna have the pistons coated and looking into the exaust runners in the heads, possabily(sp) the exaust valves.
4C FED
Absolutum Dominium
That subject has been brought up before.
With the surface coating the feeling was that with forced induction, combustion chamber temps may become to high therefore increasing the possibilty/risk of detonation.
I remember someone (WindedV6 I believe) who is currently having a motor built who is having his pistons coated by Swain. Hopefully all will go well and he will have some feedback about the coatings issue.
At $40/piston it could be an expensive experiment, especially if it has negative benefits.
4C FED
Absolutum Dominium
I'm wondering if anyone has ever modified the stock pan for increased capacity?
Not necessarily make it deeper, but it could be made wider like most every other aftermarket pan. I think that making it wide at the bottom would really help keep the slosh down.
Something like this:
Or I found this: http://moroso.com/catalog/categorydisplay.asp?catcode=11108
Looks like Moroso will make a custom pan, but unfortunately the custom order form page doesn't work.
myclone
Rick,
I think about doing a deeper pan prolly every time Im under my truck (which is a lot :) ). I havent put any real serious thought into it as there isnt a whole lot of room to extend the sump but still keep it above the cross member. There isnt a lot of room to go "out" as it would prolly make removing the starter/front drive shaft nearly impossible or more of a PIA (if thats possible). Least for me the stock pan is adequate.
Just a thought though. I dunno if you have noticed that a 2wd 4.3 pan is not NEARLY as "deep" as a 4wd (syty) pan. The 2wd pans sump is "longer" front to back to make up for not being as deep. The 4wd (syty) pan on the other hand is much shorter but much deeper. It has to be shorter to clear the cross member. IMO that "deeper" 4wd pan helps keep the oil in the sump in high g situations but could prolly be sucked dry during extended high rpm with a high volume pump as the oil capacity is the same, or very close to it, in both.
I guess I coulda saved myself some typing and simply said... IMO if the eng will see sustained high rpm/wot then extending the pans sump capacity would prolly be a good idea. LOL..
