TYTILIDIE
METH HEAD
Build:
Bowtie block 388 casting .30 over
Forged Crower Crank with 2.1 rod journals 3.5 stroke EVEN FIRE
JE pistons 9.89:1 compression
Stefs aluminum oil pan
Comp 3 piece timing chain cover
Cometic head gaskets
ARP head studs
Bowtie heads 2.1? intake valves (I know they are bigger than 2.02's)
Heads fully ported
Crower offset lifters
Manley Pushrods (7/16" if I remember right)
Custom Bullet Cam
Jesel 1.55 shaft mount rockers arms
RPM valve covers powder coated with oil fill and breather fitting welded on
Tilton Mini starter
Custom headers
GT42R turbo or (76mm) with 1.01 A/R T4 flange
Custom stock lower intake to match the Bowtie heads (you can run the stock plenum or I will throw the custom plenum in that you see in the pics)
Holley 58mm Throttle body
Fluid Damper
MSD Billet Distributor
Not sure what else to put here but, that's it in a nutshell. I have spent a lot of money on this thing, about $14,000.00 just in parts and machining.
I am asking $10,000.00 from top to bottom side to side. I'll even throw in the radiator support, aluminum radiator with electric remote pump, all plumbing and fmic (no piping or fittings). Anyone wanting the tack and pinion with mount and sleeves can have that too.
