Bowtie Roller Lifters
Lynn D. Brown
Bowtie Block guys :
What did U use for lifters on the Bowtie block ? According to Conleys', the stock type Lifters w the flat sides - where every set of 2 Lifters is contained by an aluminum retainer - will not work.
He thinks he will have to go with the type of roller lifter that come in sets of 2 tied together by a strap. These R the same type of Roller Lifters that R used in GN 3.8 blocks when U go w a Roller Cam there.
He is thinking that he may have to go w 2 different Pushrod sizes also. Anybody else have to do that ?
bigtime
Sy-Ty Builder
Comp cams and crane (crane #11532) sells hydraulic roller lifters
with the tie bar (retrofit). Pushrod's you will have to check geometry
after you install them.
