atomicmecha
I hate rust
So I've got this wild idea of a minor upgrade I'd like to do while the top half of my engine is torn off. The vac lines in my typhoon are already cracking and falling apart and I've bandaided it and patched it best I could for now. But now that I'm doing a top end rebuild, figured what better time to just replace everything with brand new silicon hoses.
BUT one of the goals of this whole refresh project is to also make the entire engine bay cleaner and easier on the eyes. So if I can, I'd like to run a nice custom fitted set of lines. So I'm going stainless braided lines.
What I need help/advice/etc on is the following:
What size line should I use? -4an? -6an? -8an? I'm thinking -4an...
Which fitting sizes's do I need to tap into the engine?
I have three spots in my notes. One on the front that feeds the accessories and vac ball. One under the throttle plate that feeds the vap canister. And one behind the manifold that feeds the map and fuel regulator.
I also have scribbled here that the fittings are 3/8th's, but is that right?. And is that a 3/8 NPT fitting? Are all 3 the same size? And if that is the correct size, a 3/8 to __an fitting would work I'm guessing.
I plan on going all out on this kit. Getting hard elbows. Hard t-connectors. Everything. Ordering a good 10 foot worth of hose once I decide on the size. That way I'll have enough to do a full replacement and some left over for when i cut a piece too short. :lol:
Probably sounds crazy, but I think it'll look awesome and very clean when I'm done. I'll also take plenty of pictures and exact measurements of each section of hose. Once its all done I'll post a full list of what I used as well. :tup:
