Brake Bleed Problems
sy2675
He Saved the Pimp'n Game!
i just finished the ABS delete, and cant get the rears to bleed, i have searched for a while and still havent found the correct way to bleed the rear brakes :rant: , fronts bleed jsut fine, rears only spit out a little fluid and the pedal doesnt move while attempting to bleed them, should i use some sort of vaccum to pull fluid thru the lines? HELP PLEASE! :tup:
Luke
Fish sticks SUCK !!!
Re: Brake Bleed Problems
i always gravity bleed brakes,takes a while but you can do with 1person. or have buddy sit in truck, all valves closed and open the r/r, have him push and hold,close while he is still holding till you start to get fluid and repeat as nec.
KETCH-UP
A Vacuum bleeder kit from Sears, works well for me! Auto stores may have similar. Just keep resevoir topped off, and pull vacuum from bleeders.When no air bubbles come out good to go!
Bill Z
If you brake pedal doesn't go all of the way down when bleading the brakes, you have gotten something in the line some way, some how. You need to all lines are free flowing.
syclonekid43
same here. i fond that the best way to bleed them.
