Brake pad & rotor change. Need some quick help.
AutoVation
Well, I'm 4 hours into it (2 trips to the store/stuck caliper piston/breaker bar on a c-clamp...) and I've got a question regarding the sleeves for the 2 allen bolts holding the caliper up. The sleeves came out when I took bolts out to remove the caliper. I can only get them back flush with the caliper surface. As you can see in this picture from before I took the bolts out, the sleeves are counter sunk in the hole maybe an 1/8" or 1/16"? Does this make a difference?
Arrow points to sleeve I'm talking about.
Arrow points the counter sunk side of the sleeve. I can't get the sleeves pushed down to this point, only back level to surrounding surface so there is no countersink.
Also, is pretty risky to run the brakes with the rubber protecting the caliper piston being torn? This is the condition it was in when I took it apart.
Re: Brake pad & rotor change. Need some quick help.
I would replace the calipers personally. Do you know that you not supose to compress the caliper piston with the bleeder close? (Not sure if you did) Doing so will often push the brake fluid crap back into the ABS and perhaps ruin the already finicky ABS. The right way to doing it push the caliper piston back with the bleeder open. Now is a good time to pump fresh fluid through your brakes anyways.
QWERTYphoon
Motley Driver Award 2009
Calipers are cheap. The sleeves you refer too are self seeding, just make sure you tighten the allen bolt. I usually sand them by hand or bench grinder real quick so they slide better when I install new pads.
AutoVation
of course i opened the bleeder. every post on pads says to do it. :tup:
AutoVation
I tightened the allen bolts as much as I could by hand with a big @$$ allen wrench. Is it good to go?
ty166
looks like bare minimum you should have replaced the front hardware, in picture two it looks like a giant piece of the o-ring bushing torn and hanging out.
Tooky
Serious about performance
The front calipers are so cheap I think you can get them for under $10 a piece. No kidding.
I would recommend getting a 3/8" drive hex socket for the caliper bolts, allen wrenches are pretty weak. You can also torque it properly with a torque wrench that way.
AutoVation
Yep, I'm going to replace the front calipers and might as well do the brake lines while I am in there...
:rant: This is nuts. When you hit the brake and nothing happens then cream the car in front what ya gonna do?:rant:
AutoVation
Uhh... stab it and steer it! :rotf:
