BoostedSUV
Re: breaking up, stumbling, surging! wtf!
Yes there is an Autometer boost Gauge, it reads -15 at idle in park. When I slowly bring up the RPMs the needle will drop to about -18 then the truck breaks up at 1100, 1900, 2400 everytime and seems ok in betweenand above those RPM's but the vac reads -15ish when it's breaking up, I can steadily increase the throttle but theres a delay before the RPM will increase.
I have an EGR delete and the entire EGR system has been removed from the truck.
Have you got a vacuum/boots gauge (not the factory one) hooked up? What does it read at idle in park, and during light accel. when things are acting up?
Also, is your EGR functional? If so, try disconnecting it (remove & plug the vac line) and see what happens.
