Brodix Head Pushrod Length ---
alwayscode390
pppssssshhhhhtttttttttttt
What length pushrods are you guys with Brodix heads running?
I will be using roller lifters, 1.6 roller rockers, and a 422 cam
Should I wait to let my builder find the specs, then buy them ?
Do you think if there is ONE part to let the engine builder tell you about, its the pushrods? I like to purchase parts and hand them to the builder. THANKS ---
Z SKI
Re: Brodix Head Pushrod Length ---
Nate,
I think it all has to do with deck height, head gasket thickness, heads (if they have been surfaced), rocker stud height, rocker ratio, etc.
I will be buying an adjustable push rod length checker to ensure that I get the correct length. This will help me end up with correct roller tip to valve stem alignment throughout its range of motion.
Hope this helps.
See ya,
It's just a six
Super Member
I believe you need to know if you have stock length valves also,,,.050 .100 longer
Like stated earlier, get a push rod length checker.
