WyoSyclone
Well, I've been going over my Sy with factory manuals just making sure everything is tight, adjusted right, etc.
Since I've had it, it's had the loud ticking noise. I bought a stethescope and found the ticking come from the injectors, and decided to adjust the rails and injectors up a little bit. The rear bolt loosened just fine.... went to loosen the front bolt and it snapped almost the second I put force against it. So, I imagine whoever put it together got gorilla-like with the wrench.
I thought no big deal, I've removed plenty of broken bolts. I went down and bought a couple of different types of easy-outs, drilled the center of the bolt and tried to budge the remains. Not even a budge.
I soaked it with CP penetrating oil, then WD40, then back to CP. I did this for two days and took my heat shrink gun and heat the aluminum up repeatedly - that usually at least breaks the crud loose.
Well, long story short - all that did nothing. To top it off, I went out tonight to try one more time with the easy out and murphy's law took over - I broke the tip of the easy out off!!! :rant: :rant:
So, now I'm stuck not being able to get the tip of the easy-out, out of the bolt. Everybody knows you can't drill through an easy-out. Does anyone have any ideas??
I know I can't drive it like this cuz the injector could pop up out of the bung and spray fuel and cause a fire.
Anybody got some helpful words? Even if I took the manifold off, I still don't see a way to fix it.
Arrghh.
Arrghh.
