bezerk said:if you try you can use a screwdriver to push the lip, where the cable is normally atached too.
**** dude,you should be abe to open your hood no prob.Grimgrak said:Ugh I tried pounding it with the screw driver and now my condensor is crushedTook it to a shop and they think the hinge is misalinged somehow wtf?
Jimmy said:**** dude,you should be abe to open your hood no prob.
Shine a flashlight in that bitch and see what you are dealing with.
All you gotta do is push that lasso shaped piece backwards,
A retard could do it with a coathanger.
You need to push it backwards.Not stright back,but at an angle towards the driverside corner of the hood.A putty knife would work well.Grimgrak said:I tried to push the peice that the cable hooks into towards the steering wheel which is the direction it would go if the cable was pulled. Or do you mean I should hook it and pull it away from the steering wheel towards the front of the truck instead of pushing towards the back?
