Broken Typhoon Tailgate Handle
sytyguy
Moderated User
I haven't had a chance to really investigate this yet (we're on vacation in the mountains and the cylinder broke just before we left), but the lock cylinder just spins (full 360 deg in either direction). I popped & opened the glass and went to drop the gate and the handle just started spinning. You can hear it attempting to grab the lock rods inside, but they slip. Delicate attempts we're futile, and I couldn't easily see a way to drop the gate manually (wedging a flat head in the latch ends, etc...), so we hopped in the Silverado and took off.
So, when I get home, I've got a broken cylinder to replace on a tailgate that won't drop so that I can access the trim panel. Luckily, the glass pops via the button just fine. I'm sure I can figure it out once I'm home, but if someone can give a pointer or two on dropping the gate, I'd be much obliged. Replacing the cylinder is no problem, but haven't dealt with a stuck gate in recent memory.
Now I remember why Syclones are better.....:rotf:
KDBL1TY
Re: Broken Typhoon Tailgate Handle
Try the flat screw drivers only on both sides. The solenoid inside the tailgate releases both at the same time.
DaveP
Solenoid releases the glass, Bozo. Not the gate. Read the OP again.
DaveP
Re: How to Open the Tailgate w/ Broken Handel
Open the glass. Look down inside the opening, to the left of the glass 'catch'. You will see one of the 10mm hex nuts that hold the catch assy into the gate. Use this nut as reference.
In this pic, the pencil is pointing to the lever that releases the gate. See the stud that the 'refrence' nut would be on behind the pencil. The handle assembly (not pictured) pushes down on the lower lever to open the glass, and UP on the upper lever to release the gate. This lever assy needs to be rotated clockwise to release gate. Use a medium screwdriver to push it towards the RIGHT side of the truck.
Here's another view, but from above, and similar to what you will see looking in the hole. See the lever you're after is "U" shaped. You can hook the screwdriver in this "U". Remember, to the right.
This should get you going. Happy New Year, Mike.
DaveP
So sorry ! Ur such an expert !
I'm pretty sure I know a hell of a lot more about these trucks than you do, and I DON'T GUESS. If I don't know, I don't post squat.
If you don't know the answer, and are GUESSING, don't post, and wait to see if somebody DOES know the answer, and learn that way.
If you had just paid attention to what Mike posted (the solenoid is working, and the glass is open) in the first place, we wouldn't be having this exchange. And if you owned one of these, you would know how the gate works, and not gotten it 'wrong'. (Sorry, Mike)
People that THINK they know it all, tend to annoy those of us that do.
Jimmy
Banned
Captain Morgan
Moderated User
:eek:wned:
DaveP
sytyguy
Moderated User
AWESOME.....thanks a million Dave! Should make this repair a ton easier.
Happy New Year to you as well!
ziembic
Well said
