Broken water pump pulley stud.
syntax
Well, started to hear a clacking sound coming from engine bay and low and behold at first glance a stud and nut are missing from water pump pulley. At second glance, a stud is broken and now stuck nside pump. I do not run a mechanical fan. So waht are my options? the sound of it makes it uncomfortable for me to drive to drive, how do i go about removing the broken stud? it is not long enough on either side to get a wrench on, is it something a normal drill can take care of? its a new eldebroch pump so i really dont want to reaplce pump, all thou i realize i will have to take it off to fix it, any advice is appreciated. thank you.
NecroWolf
lost marbles member
Re: Broken water pump pulley stud.
drill through it and use an extractor shouldn't be too hard. just make sure you use the right size extractor. if it sticks out enough one either side you can cut a notch in it and use a screwdriver to back it out.
