bs3 conversion, stock dist or crank trigger
MIGHTYMOUSE
Turbo F body guy
im about to pull the 'trigger' with john to send me a box like i have in my ws6 to run the ty.
the truck currently has no spark problems, but that doesnt mean i couldn't have some in the future.
he asked if i was going to leave the stock spark set up alone or wanted to go ahead with a crank trigger.
what has been sucessful for you guys.. and then a link to the place that makes the crank trigger parts would be great if that is the best way to go.
thanks
autoaddictions
Re: bs3 conversion, stock dist or crank trigger
thanks
Im running a big stuff you dont need a crank trigger. You can also buy a SYTY plug and play harness! Mike at RPM gets them. You should have a upgraded IGN. Box regardless MSD,CRANE, or whatever if your intending on making any serious power.
MIGHTYMOUSE
Turbo F body guy
right, i have an msd box and coil, and the box will come with a harness of course.
what does yours run or make at the tires with a standard cap/rotor/coil box configuration?
autoaddictions
I havent been able to make a clean pass on a dyno yet due to converter lock up issues on my 4l80e. I havent been back to dyno since straighting out the settings. However i was able to run 10.90@126 at the track. The big stuff system is a very good tool for tuning however you must read the manual 6 time or so to retain any information from it. Its very comprehensive.If i were to take a good guess on hp #s id say 600hp is close my TY weights 4200 with me in it.
MIGHTYMOUSE
Turbo F body guy
thanks.
i would like to hear from at least one person with a crank trigger set up before i go with the stock style
MIGHTYMOUSE
Turbo F body guy
well the new box and harness should be here today. i went with what it will take to run the factory stuff for now, no cop, no crank trigger
look forward to the searching i do on here for the questions everybody asks, what wire where type of thing. etc.
