BS3 tuning discussion
0966Sy
Code what?
I have sense completed my BS3 installation on my stock Ty with 50#'s. I am pretty familiar with how to navigate through the program and make changes in cell's. I've been at it for two weeks starting from a base file and working my way through the BS3 manual I have printed out and put in a 3 ring binder (back to school)
I'd like to discuss further in certain area's im trying to grasp beyond what the manual has explained.
Most important to me as of now sense I seemed to have overlooked it is, inductive timing delay. Frank had brought it up in another post of mine seeking a startup file. I have my base timing set to 0* at idle@950rpm is where I found the best idle. The manual states to perform this test at 2500 rpm with the Static Test Timing enable test timing box checked. Basically watch the live RPM in the DASH on the Bs3 and compare it to the mark on the balancer. 12*adv is the most on the stock balancer, Is there a trick to finding what number I need to put into the crank reference deg, and inductive delay box under crank trigger in the operating parameter config. Right now mine has 6.0 crank reference, 26 inductive delay, 30* test timing and 360* crank reference (COP)
Not sure about the best way to go about this, trying to understand how whomever got the number 6.0 and 26 at this point.
sharkbait
Re: BS3 tuning dicussion
im stupid. gonna look this up on the internet. ....cause anything you read on the internet is true, right? lol. i defiantly wanna watch this thread and the input given by top gun/guru guys.
ziembic
Well you were hit by a car, so we will give you some slack.
denny
Re: BS3 tuning discussion
Crank Reference 6.0 deg I believe is the default value, I never changed this value.
You add or subtract Inductive Delay until the actual timing(at the crank) matches what you have in the Test timing(deg)
Thats my understanding.
Eric Sy GN
It doesn't matter what timing number you put in there, as long as it stays at that number when you bring the RPM's up. Use a number you can see on your balancer.
For example, lock it to 10*, check timing at idle to see if its 10*. Then rev the motor to, say, 3000rpm, and see if it's still holding 10*. If not, bump the inductive delay up or down until it matches.
Regards,
Eric
RealFastV6
@jb_and_his_coffee
Let me see if I can expand on this a little bit.
There's two things at play here...
Crank Reference Angle is what you adjust to get (lets say 30 degrees) on the hub to match 30 degrees on the ECU at a fixed RPM. 6 is the correct number for any GM HEI ignition. I don't know if that's in the BS3 manual, but it's in the XFI manual. For a SyTy, you set that to 6 and you're done. If you had an LS1, you'd set that number at 10. If you have a GN, you also use 10.
Inductive Delay is what you adjust in order to calibrate the unit to your truck to get your 30 degrees to stay at 30 degrees throughout the entire RPM range.
sharkbait
i dont wanna say it but i have a TBI (traumatic brain injury) and i slows me down with some of my thinking/problem solving/ memory lol.
thanks ziembic.
0966Sy
Code what?
Thanks a lot guys! So if I change the 30* to 12* in the test timing box and enable the test timing I should see 12* in the dash display in the bs3 while I see 12* at the balancer with my timing light. I would assume you leave the white wire HEI timing connector plugged in for this test.
Also, is it possible if the test at 12* match's up with the balancer that a test at the 30* it's at now does not?
So if my test at 12* is off I would adjust the delay number up or down until the dash display match's the 12* on the balancer?
Eric Sy GN
Yep, you got it. Leave the timing connector plugged in (if you unplug it, it will just go back to 0*).
It should not make a difference, 12* or 30*, just use the number that is easiest to see on the balancer/timing tab.
Regards,
Eric
autoaddictions
I think wen I did mine I changed my hole timing table to 10 then I grabbed my timing gun and added delay while looking at my laptop until the matched no mater what rpm I held the throttle at. I think I need 690 ms wich is a lot. But it works. Checking the bid I think does the same thing at changing all the timing tables. Just with one click. I just wanted to be sure
0966Sy
Code what?
Going to take those steps suggested to confirm my delay thanks again for breaking it down Erik, frank and Denny.
I'd like to figure out how I can take advantage of the transient fuel tables. I've read there description in the BS3 manual. Just not sure if this is something that needs to be on all the time or only for fuel tuning purposes. When I get to it I'll describe what settings I have that appear to have it disabled past 120*f
0966Sy
Code what?
Not to sure what my ve% should be at idle with the 50's. at 14.7afr I'm between 65-67%ve. I leaned out my cruise fuel closer to 14.7 and it extremely help my o2 correction at cruise
0966Sy
Code what?
Looking for some tips on keeping my afr from leaning out at wot after my 2,3 and 4 shifts. My fuel correction is within 3% except for these area's. I've added up to 20% more fuel to those cells during shifts and it has seemed to help some. Trying to keep the afr at 11.5 in those lean areas after shifts. Could I adjust the target afr in those cells lower to say 10.5-11.0 to keep my afr streamline at shifts. Just asking as I'm not sure if I'm missing something in transient fuel
0966Sy
Code what?
I adjusted my desired afr linear down from 11.5 to 10.8 in those cells and it is keeping the afr in the 11's now after the shift. I pulled the fuel back out of the cells to match a good +/- 3% correction. Running really strong with 14* timing at 18psi with the ur5's looking great. Going to try some ur6's to maybe get some more timing on 93 pump
autoaddictions
I would consider using tr6 pugs. And I think 14 *@ wot could be pushed up a bit. Especially I'f your running vortec or better heads.
0966Sy
Code what?
Frank, I'd love to be on vortec's. This is my Typhoon with a stock l35 head motor and a 20g turbo with stock IC. My goal is to get it down to a 12.50 on pump gas if I can get there. I ran a 13.40 @97 with a shitty 2.0 60' on low timing with 16psi. I plan to run the BS3 in the Sy with a built vortec motor. The BS3 in the Typhoon is my test mule to learn on. So far I'm loving it!
0966Sy
Code what?
I have a 60e case I plan on building for the Sy to control with the BS3. Are you running the BS3 with trans control for your 80e frank? If so how do you like it?
autoaddictions
I am running the 80e from the BS3. It works fine its nice to have it all infront of you at one time on the laptop. You can datalog the transmission info too. My only complaint is you cannot lock uo the converter in 1st and 2nd gear. This isnt a problem for daily driving however for dragracing its a nice feature that could shave some ET.
