buddy's motor
Syclone#2960
What ever it takes!!
my motor.
Silly
Banned
Re: buddy's motor
Looks good! good luck fining the knock.... do you know it is legit knock?
Syclone#2960
Re: buddy's motor
I'm getting knock counts in park. When i rev it up to about 3k. Going to try a few things.
Disconnect the msd box. Check flex plate for cracks.
Maybe add better grounds.
Silly
Banned
Re: buddy's motor
Have you put good fuel in it and still gotten the knock counts with the higher octane?
If so then you might just have sumtin loose.
Not sure if that helps just tryin to save you some time.
I had a false detonation problem in my old syclone that I never figured out... ended up selling it for that reason pretty much.
sy#2921
BAMF
Re: buddy's motor
memcal, ecu, ignition module, chip adapter etc. False knock will drive a man crazy but you will learn the ins and outs real quick
Syclone#2960
Re: buddy's motor
this truck has been down since 2005 and finally had a chance to drive it a couple of months ago. Maybe 100 miles in this motor & tranny going to an allignment shop & gas station. Been working on the ty instead. The ty is fixed now, time for the sy.
Syclone#2960
Re: buddy's motor
Just a little update on the knock issue. A piece of the block flaked off from the lifter valley and made it's way into the oil passages. Had to replace the crank & bearings. Should have it running again tomorrow evening..
nallj92
Re: buddy's motor
how is the turbo blanket working out for you? is it the larger or smaller t3/t4 one?
Syclone#2960
Re: buddy's motor
It's great if you are running an external wastegate. I'm still running the internal WG which makes it harder to wrap around snug. I bought it locally here in Austin from Protech Performance (ebay).
