Budget Timing Chains?
Throws
Not doing an all out rebuild, just a "refresh". Basically, I'd like the motor to stay in one piece, while I build up an eventual (eventual being the key word) replacement. So, not looking to spend a ton of money on something that's going to get pulled out in 15k miles (already have 150k on the odometer!)
That said, I'd like some reccomendations on something that'll work and isn't expensive. I keep seeing roller/non-roller chains, and I'm assuming our chain is the same as a V8 (judging on other posts I've seen on the design of our engines). I do see chains that point out as being specifically for our "Z" code engines. Big deal?
Here's some chains I had in mind (Mojo disliked doubles, but I'm including them in that price point).
http://www.competitionproducts.com/Cloyes-Double-Roller-Speed-Set-Chev-SB-3-Keyway/productinfo/C3023X/
http://www.competitionproducts.com/...Chev-305-350-w_Roller-Cam/productinfo/C3064K/
http://www.summitracing.com/parts/CLO-C-3056K/
Thoughts? Other chains I missed? Brands to avoid?
-P
nallj92
Re: Budget Timing Chains?
gotta make sure its for a roller cam block/cam, I made the mistake once myself and got one for the older SBC. Depending on how you want to do it, you could get a good double roller now then when swapping motors out reuse it on the new engine as well.
I think I ended up with the edelbrock double roller for a roller motor.
Throws
How can you tell?
-P
nallj92
most of those pics are stock photos, so i wouldnt totally rely on them.
roller motor with retainer
349%3C693%3A5%7Ffp63%3Dot%3E2334%3D%3C3%3B%3D%3B37%3DXROQDF%3E23235%3B46636%3C3ot1lsi
would nee a cam gear with either the shoulder to take the cam thrust on the retainer like below. or one with a torrington bearing
Throws
I know we're fairly interchangeable with a small-block V8, but is there any constraint to be aware of? Chain width? oddities?
Thanks!
-P
Something not mentioned is to be sure to degree the cam. TMK aftermarket chain sets will come with the 3 keyway sprocket. This allows, within limits of course, to degree the cam by just changing which keyway you use. Very important that any aftermarket cam should be degreed. Stock? I suppose you time it to -0- and be done with it.
Throws
That's my plan. The "eventual" built engine will use a much nicer set and flaunt an aftermarket cam...
-P
