building a turbo
syclone3
So I decided that buying a new 20g for $800 my cost wasnt that great of a deal. Especially when I used to buy and use them in a different platforms turbo kit for $475. And went through a good 150 of them. Not wanting to buy a turbo with a custom "wheel" thats a variant once marketed to the DSM community. And looks like it fell out of the mill.
Decided to build a 20g. Having had good luck with the Kunigwa components recently. Relentess abuse and boost levels and still holding up like new. :rotf: I got one of the 9 blade high flow TD06 turbine wheels for $69. A new center section for $105. A 20g wheel and compressor housing for $150. Add in a bearing kit. Pick out one of my turbine housings. ;)
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Z SKI
Re: building a turbo
Nice!!!
I have the same exhaust wheel (with a 10 cm2 housing) for my stock framed turbo and I'm gonna try a billet 60-1 compressor wheel.. Should be a nasty little turbo!!
Do you happen to have a 14cm2 housing that you could part with??
Let m know..
syclone3
The turbine wheel I got doesnt fit a stock Sy turbine housing. I don't have any housings for sale.
Z SKI
Yea... It's the TD06H 9 bladed exhaust wheel, only fits exhaust housings made or machined for the H wheel... I have the same wheel..
No housings for sale?? Do you know where I could buy a TD06H 14cm2 exhaust housing then??
Thanks,
It's just a six
Super Member
It should be a good running turbo.
Just my:2cents:.
If I were going to go through all that work, I would not consider a 20G wheel, it's barely an upgrade over stock. It's not too late!:rotf:
I would get a 57MM compressor wheel & have the stock compressor housing machined to fit the larger wheel.
Here is a 60-1 wheel. http://www.ebay.com/itm/Garrett-60-...m3f56857c8f:m:mZK9P1Bk4XFcDTW8BCvEKtw&vxp=mtr
Here is the compressor housing for the 60-1 wheel. http://shopping.kinugawaturbo.com/turbocompressorhousing24td0620gtrustsgmc-1.aspx
Here is a billet 57 mm compressor wheel. http://www.ebay.com/itm/Billet-Comp...ash=item3f58036cdc:g:n40AAOxyVaBSqtzb&vxp=mtr
Or , just get a plane Garrett 57 MM compressor wheel & have it machine to fit a Mitsubishi turbine shaft.
I bought the same turbine wheel, good thing I posted that link here huh?
What turbine housing are you going to use?
I just got my turbine wheel today, sure does not look like the one in the auction, it looks like the blades have been clipped for greater flow.
My turbine wheel looks just like yours.
Brwndrvr05
Just my:2cents:.
If going the 60-1 wheel and compressor housing route. Would a 10cm housing with an h-wheel work well while using the stock converter? Or would the 14cm housing work better and changing out the converter also? Trying to keep stock converter if possible
syclone3
Been using turbos for quite a long time. Really don't need a big power increase on this truck. Just cooler charge air temps and a little more cfm and less backpressure. Gate is on the crossover and holds 19 psi flat on the 17c.
Plopping a garret wheel on the Mitsu turbine shaft. Whether you got a 360 deg thrust bearing, pinned or not. The longevity of the turbo really isn't there. Not to mention the surge tendencies with the larger wheels inside smaller compressor housings milled to accept. BOV or not. Then you get to the turbine wheel. And what was really the downside of running a real 14cm turbine housing 20g. Everything from slow to no spool on a stock converter. Controlling boost once it was at full song. etc. The stock TD06H turbine wheel and amount of backpressure it would produce. Now you got a pile of variables all floating up in the air.
I have never tried a large compressor wheel on a stock Sy turbine wheel myself.
Sort of a reason why one side needs to be proportioned to the other side on a turbo. Can be labeled as the turbines shaft speed to multiple surge points in a compressor map. Biggest problem I have seen with Mitsu cartridges in general is they don't like high shaft speeds nor sudden spikes. This is from data on a different platform but still using the 05 and 06H cartridges. Anyone ever wonder why a stock Sy/Ty turbo last so long?
Plus I already got a real 60-1 on one of my other Sy. Decent size exhaust wheel and housing also. On an engine that can run little more rpm than stock and has heads and cam that want the airflow. In todays turbo world a 60-1 isn't anything spectacular or large. But as part of a combination it can still run half way decent and does.
It's just a six
Super Member
Using a 10 CM housing with an "H" wheel turbine works fine, boosts just as fast as a stock turbo does.
Problem is the 10 CM housing is still pretty restrictive so a higher flowing 9 bladed "H" wheel would work better IMO.
I currently am using a 12 CM turbine housing, a 60-1 wheel, a TD06H 12 bladed turbine wheel with a stock original torque converter.
It runs fine for a daily driver, no complaints what's so ever & has run a best of 12.0 & dyno tuned to 396 HP @ 23-24 PSI boost pressure. The engine is 100% stock untouched long block.
A 60-1 wheel is really 59 MM for the most part, the 57 MM wheel is just a tad smaller & still will work good & you can easily machine your stock compressor cover the fit the 57 MM wheel & be all "stock looking"
A 60-1 wheel, is too large to fit in a stock compressor cover, not enough material.
I had machined a billet piece of aluminum for a 3" OD then had it welded to a stock compressor cover , then had it machined to fit a 60-1 wheel.
