Building boost
AXXE
I know I have posted this before, but I cant figure it out. With the Ultimate on 18psi settings, my truck only builds 18 in third. It makes about 16 in 1st and 2nd, unless it is very cold. Then it is fine and goes right up to 18 in all gears. Any suggestions?
Ian Turgeon
Cascading Inspiration
could be air restriction somewhere.. most likely the exhaust.
Open it up, and the stock wastegate may not be able to control it ;P ah, the 2 way battle with the stock turbo.
smeagol
Have you tried adjusting the wastegate?
Have you tried adjusting your fuel pressure?
Have you tried replacing your vacuum lines to your wastegate actuator?
What have you tried so far?
AXXE
I replaced all the vacuum lines. Fuel is good. I adjusted the rod about 1/4 turn and it seemed to help. How much should I adjust the rod? What is a safe limit?
TheObiJuan
Would I need a chip like that even if I had a boost controler? or would that be redundant. does the chip also manage fuel?
What is better, 3-bar or the one listed above?
