brock1949
Its alive!!!
Well, here is the deal... I am going to be running a PT60 turbo, stock manifolds, hopefully a syty computer and harness later this year... and my goals are a solid solid motor able to handle running low 12's in a 2wd s10 reg cab short bed or even high 11's if i get crazy but thats really not the goal...I just want to have a bottem end i don't have to worry about...Not trying to break records just have some fun on 1/4, street and road coarses...
The machine shop thats going to be doing my work told me that they have build some high HP 3.4L's and they kept having block failures so they eventually talked to a cryro company that would cryro the block he told me if i wanted it bullet proof to send it to be cryro'ed with the crank. So i'm wondering if anyone has done this ?
Also for the crank cryro is better then nitride right ? its only to like a little under surface? OR can you do both?
And the 4 bolt mains, he told me they would do 4 bolt on the two center and might be able to do a billet 2 bolts on the ends? What is standard practice here? Should i do 4 bolt centers and keep the factory sy ty 2 bolt mains on the ends? i could also have them cryro'ed...
Also i've been told a couple times i should just have it bored .30 over to start with? is this true or if i can limp away with a hone or .10 should i do it?
Now how about connecting rods? I am looking at Eagle H beams or I beams.. i've been told go I beams a couple times now just wondering what everyones thoughts were their, or if their is another brand in that price range better?
Pistons it looks like i'm going to be getting TRW .30 over from someone on here new, or a freind has a set used in florida he said i could have cheap.. i dunno about used pistons... and are the TRW's the way to go?
I have a cloyes true roller timing set i'll be reusing if i can from a BS block single roller..
ARP hardware all around...
Any special bearings i should use or anything like that in this motor ?
harmonic balancer ? whats a good cheap one...
Anything i'm missing ? Any pointers etc etc?
I've searched and searched and i just couldn't get a good list going and no one seemed to agree which i don't think they will here but looking for some pointers... The machine shop is owned by a freind so i get pretty awesome deals plus they get a kick out of the 6cyl builds... its just shear cost of parts killing me...
Thanks everyone!
Thanks everyone!
