nallj92
Re: Built Engine ideas
I had a 422 and sold it for a campbell custom grind. The combo changed so much between the two that I cannot say accurately if it was "better". if your buying a cam new i would look into a custom grind, but if your looking used, i think a 422 would be fine, it all comes down to budget.
Off the top of my head.....
Block: 4 bolt splayed, half hardblock fill, JE pistons, eagle rods
Heads: ported 2.02 1.60 vortecs, custom campbell automotive camshaft 1.6 Comp roller rockers, edelbrock double roller chain
60lb injectors, alky control dual nozzle kit, 58mm throttle body. Ebay FMIC, PTE 63mm Turbo. TCS9/11 3300 stall converter, Built 700r4 trans
I have been too lazy to get it really dialed and tuned in all the way, still fighting some false knock, and contemplating selling the motor and doing a LS swap.
hth
Justin, didn't you go to a Custom cam instead of your 422? If so, did you notice a difference? Also can you please give me some more info on your build since we have the same Turbo?
Thanks,
hth
