b-rad420247
Re: Bulk connection at firewall question
Ok everything but the 2 vss wires or hooked up......
Check engine light works, fuses good, fuel pump turns on and I get pressure in the fuel rail, it has spark, spark plugs look wet.......
It cranks but will not fire......And when I turn ignition off the fuel pump runs for a bit before stopping.....also I have the stock s10 fuel pump and sending unit in it but I do have the 255lb pump and Hotwire kit, just haven't installed it yet.
