burn the chip for injectors????
Raist103
I am adding a Walbro 255 HP pump, some injectors, and a adj. regulator. I was told that a stock pitbull chip(ATR) MAY not work if I change the injectors, so I must burn a new chip. The injectors are just freshened up green tops from my GN before I went big with 55's and for that I had to burn a chip but not with the green tops and my dad had 009's on his GN and he did not have to burn a chip. I am new to ty's so any info would be a great help. Also after I put my pitbull in the car only runs to 4k RPM's then shifts, should it not be 6k like it says in there catalog??? My mods are as of now a TE-61, 3" Downpipe w/ wastegate, chip, and a 160' stat. I am sure I am forgeting something but for now any info would be a help.
jwaller
Evil Genius/SyTy Guru
its not going to run right...if you put ANY chip in there...as long as that chip is not calibrated for that injector your screwed....the ATR KB and all others that claim to have 40lb chips are full of it
smeagol
By green tops, I'm assuming you mean 33# Lucas. They've changed things, now the 33s, 38s & 42s are all green tops. Anyhoo, if they're the 33s, they'll work fine with any calibration that is made around the stock injectors, as the 33s really don't flow any more than the stockers, and are about identical.
just a 6
R.I.P MyClone
Brian, so i can install a ATR strip chip that is made for 33# injectors and run it with my stock injectors???? I'm worried that it will run to lean with that chip and stock injectors? Thanks man.
smeagol
Shouldn't have any problems once you tune it for fuel pressure etc. Considering that ATR didn't do much of anything for their 40# chips, I'm guessing they didn't do jack for changing to the 33s.
Raist103
I guess my next question is where can I get a chip burnt, and does anyone have injectors and a chip for sale?? Thanks for all the info.
Raist103
I took another look at the injectors they are red strips not green tops, I guess my dad had green tops then 009's any one know what they flow?? and if there is a chip made for them??? Thanks again.
smeagol
If they are the true red stripes, 38.5lb/hr about... check the part number versus that on http://www.gnttype.org to identify.
If they are 38.5's, I don't think anyone has done a chip for 'em. I don't like 'em at all.
KB & ATR's chips for them are *horrible*.
Raist103
What is the 10-1 chip and what would be my best bet now? I have been told by a few people with bigger turbos that stock injectors are fine with a good pump which I have(Walbro 255 HP) and a 7th injector for 3rd gear. Any ideas on this and ATR told me today that my car is only shifting at 4k rpm is because of a little blk button by the throttle body that you can move up and back 1 click at a time to make a rpm's shift higher. Never heard of it but maybe...
jwaller
what they are talking about is the TV cable...and by making is shorter...you CAN change the shift points....but only very slightly....if its shifting around 4 and does it all the time your governor may be stuck..
just a 6
R.I.P MyClone
Thanks Brian,
0260N4
I have about the same mods that you do, except a te-63 and no 7th injector. First of all ATR BLOWS! DO NOT call and talk to them b/c they do not know shit. I think that I have the stock injectors (red) and can not run any more than 12lbs. of boost. Might just be my truck but one day it will run fine on 47lbs of fuel pressure and another day it will be spitting fuel out the tail pipe w/ this much pressure. I would not bother just get injectors and a different chip and save yourself the hassle.
