tbauer03
TRBOBOX
My truck has been burning oil for a while now but i haven't been driving it much. Any way today I took the spark plugs out and did a compression test.
All Cylinders were within 10 percent and most right at 168, with cylinders 5 and 6 a little bit lower. But overall nothing to concerning. They all jumped up in similar intervals as well.
However cylinders 2 and 4 the spark plugs were coated in black which i assume is the oil i have been burning.
Earlier I pulled the lower intake and resealed it using new gaskets and thin layer of rtv on both sides of the gasket with a bead around the water ports so I don't think it is drawing in oil from the intake runner.
What would be next logical steps?
Thank you,
Spark plugs laid out as if you are looking at the motor from the front
6,5
4,3
2,1
Thank you,
6,5
4,3
2,1
