Burning oil smell
stariy
Just recently I start to smell burnt oil, not al the time though. I think it only if I push it, like it spills out of open hole… I look, can’t see any leaks from top. Look under trany little wet with engine oil. Where is it coming from? :cry:
Loeryder
Most common oil leaks i know of...
Turbo oil return line.
On the pass side of the pan just above the trans lines, have fun gettin' in there.
drain plug, get a magnetic with a sealing washer.
pan gasket, heard its next to impossible with the engine in there.
valve cover gaskets, check around the intake
stariy
Thanks.
Thanks,
Drain plug is OK, just did oil change. Valve cover gaskets are due but no visible leaks.
Oil pan is dry.
Turbo oil return line sounds like possibility: what do I do if it is leaking?
:roll:
0-60N4
blow by
blow by
Could be blow-by vapors you are smelling. Ring wear or pistion/ring damage can cause oil blow by. I was smelling the same thing and getting exessive blow by just before my original engine slung a rod threw the oil pan. Not to cause alarm, but you should get it checked out.
Jim
dourtyb
Another spot prone to leaks is the distributor. I've had several trucks that leak down the back of the engine from this area. A 50 cent distributor gasket from the auto parts store usually fixes it.
stariy
Thanks guys. Engine was rebuilt by dealer 15K ago so I hope my insides are OK. But I will check distributer thing for sure :D
Mephisto
These trucks are cursed
i also have the same problem... i got under my truck and snooped around and noticed, what i think is a leaky oil return line, but i cant tell... the fluid is pretty dark so im asuming its oil, but it could be dirty tranny fluid?... its a metal line thats coming from some where in the engine area, then near the oil pan, it attaches to a red rubber hose thats about 6 inches long, with metal ends on it, which is where its leaking. even then im not sure if that could be causing the burning oil smell... would a compression tell me, if shit is about to go on my engine? i.e. blow by etc..
