Bushing shells p/n.
canadian
sy in progress
Looking at the JS instructions where it says to re-use the upper A-arm bushing shells. I'd prefer to get everything set up before even starting to do the project, so does anybody have a source for new ones?
warmpancakes
Re: Bushing shells p/n.
3
You have to buy new bushings and burn the rubber out, Beavis has some shells, if he says he doesnt hes lying I gave them to him:tup:
juicehead9
93 Typhoon # 0973
the uppers are ez try the lowers if the upper shells are good just reuse them. thats what i did. if any one has any good ideas to help that would be great.
vinnieTy
TY # 1889
Torch is your friend!!!!!!!!!!!!!!
I went crazy on one side but when i started to search on the forums someone said torch it and i tried it and WOOLAA 10 minutes it was over. I cried that i didnt do that to the other side.
No reason to do the lower as the new ones come complete.
canadian
sy in progress
I know how to get them out of the arms (have a spare set of old arms in the garage), but I figure if I'm going to be doing everything else new, why bother putting old crapass shells back in? Doesn't make sense to me. So far Ken is closest with "buy new ones and burn the rubber out"...
It only took me 5 minutes to get the old ones out with a ball joint press and an old socket. No smokey smoke in the garage either.
juicehead9
93 Typhoon # 0973
How so you remove the lowers thats what i need to know i pulled the bolts but could notget the arm to drop.
canadian
sy in progress
If you're talking about the a-arms, you need to pop the torsion bars ouf of them before they'll drop.
