Buying my sy tomarrow!!
NeedaSY
Go Ahead N Go
Well besides the fact that i wont be sleeping tonight. I got some questions????? The guy told me that the intercooler leaks so i have to put water in it to make it home so how much will it take to fill it so i can bring water with me?? Also this truck has a chip that is controled by the digital gague in the A pillar so if someone can tell me the name of the chip and what its capable of that would be awsome he said i have to leave the reading on t115 to run pump gas and you can turn up the boost to 18psi. It also has a walbro fuel pump. Info please new too turbos but i know pretty much everything about engines so fill me in.
SYO237
SyTy Registry
Re: Buying my sy tomarrow!!
Bring a gallon of water, distilled.
You can drive the truck with low coolant or none in it without harming it. I dont recommend doing any heavy driving and getting into boost because without water, you essencially dont have an IC system. I drove my truck back from Nats 99 roughly 300 miles and then probably another 500-800 afterwards without coolant after running over a retread and having it rip out the petcock on the CAC underneath.. Just go easy until you fix it.
I would find that leak quickly though. If its leaking from the IC resovoir on top, it could be draining into the TB and into the intake. You dont want that headache.
The chip is an Ultimate. Leave it on T115 until you get to know the truck, tune it, get help with local owners, etc. The chip is capable of turning your motor into scrap metal unless you know what your doing with it.
wheels
Sounds like a ultimate chip. http://www.sytychips.com/
NeedaSY
Go Ahead N Go
so i geuss it will be ok to drive the truck home with no coolant since its like only 30miles.
Cool thanks O another thing syclones take normal auto matic tranny fluid right i got to get it flushed?
SYO237
SyTy Registry
Dex III, do not put synthetic in it.
Dont take this the wrong way, but I really suggest you do some hardcore searching and reading on this site and do your homework. Simple questions like yours turn into huge problems later if you dont know the basics.
Get some pics up when you get it.
NeedaSY
Go Ahead N Go
yea reading that page on the ultimate chip put me down with the turbo basics. I wont f-up this is my new baby!!
