Oh cool... well you should be able to hold a bracket up to the back of the spindle, line up the bolts in the back and see the "ear" of the spindle that needs to be cut off. Once that ear is gone, you can then bolt the caliper up. There should be plenty of pics on here though that show a modified spindle.yeah i have the whole kit with brackets.
This is the first time i've seen these instructions as well. Its a little more work than I thought it was to mount these brakes up.didn't you get the kit from me? i usually send an email with this link to the instructions:
http://www.renzfab.com/RenzFab-InstructionManual-FrontBrakeKit.pdf
This may be a dumb question, but is it absolutely necessary to remove the spindle to do this mod? Or can it be done with the right tools? (cut-off wheel, grinder, ect)its really not too bad. The instructions are pretty detailed so it lays it out as if its a 1000 step process. Really once you see/understand what needs to be done it goes pretty quickly. The longest part is cutting off the existing caliper ears and how anal you are about smoothing the edges and trying to make it look like nothing was ever there. And if you decide you need to powdercoat everything you take off of the truck like i tend to.
I don't see why it couldn't be done on the truck either. I just hate splitting ball joints because you either tear the rubber boot in the process or beat the hell out of the joint just trying to get it seperated from the spindle.brian.. would say you can do it with the spindle on.. might not be as easy tho.. ill let you know later
Thats good to know! :tup:it can be done on the truck, and has been before. I thought the instructions mentioned that. I forget...been a while since a (re)wrote them.
But i know when i trimmed the spindles it was very convenient to be able to place them anyway you wanted to get the best angle for cutting. Also, smoothing out the sharp edges would be a pain on the truck compared to in a vice.
