NJTy180 said:if I have to wire something on the drivers side, there was a hidden hole underneith the power brake booster on my truck, so everything goes through there.
If its on the passenger side, I have a somewhat large hole with a large rubber grommit in it. On the inside of the truck, it comes through under the ECM just about as high up as you can go w/o being a pain in the ass.
In order to get to it from the engine compartment, you have to remove the inner fender, but it helps keep everything hidden.
HTH
Very old thread I know.... but, ED is there any chance that you have a pic of this location from the engine bay? I think I understand it, but fear drilling before I am certain. I assume I'll be fishing the wires throug between the glove box and dash vent above the radio?ed hess said:be aware that the close proximity of this hole (its actually for the antennae) to the downpipe that wireing will be subject to heat and will deteriorate quickly, speaking from experiecne! kinda like the purple wire to the starter getting cooked.
An alternative is to make a hole on the pass side firewall viewed from the front behind the regulator to the right of the dashbord supporting stud. 1 inch to the right of the stud. with the radio out fishing thru isnt so bad.
thru this new hole i have run
1 new dfi injector wiring harness plug
2 wide band o2 wires
3 innovative msbc boost control solenoid wires
4 innovative map sensor wires
5 probably something else besides the above that i just cant remember (its an age thing )![]()
ed
