Cam I.D help
critical
meltdown
This cam came out of my Sy, and i cannot find any info on it.
It is a billet piece with these stampings
148.cpc.bc.10...
This code is not on the face of the journal, but wrapped around the cam where a traditional fuel pump lobe would go.
Any help is appreciated
thnx
mike
TYTILIDIE
METH HEAD
Re: Cam I.D help
I Googled it and got nothing. I almost want to say that # may be worthless to you. If I were you, I would have a machine shop spec it out and just see what the important factors are. When I got this KB cam, I barely found any info on it. Luckily the KB # was engraved on the front of it. Even still, info was pretty slim pickens on it,
Ry368
one mile = 5280 feet
Re: Cam I.D help
Mike the cam lobe from top of point to heel (up and down), then mike it 90 degrees from that (sideways). Subtract the small dimension from the large, and multiply that figure by the rocker arm ratio. That will give you gross valve lift. You'll have to set the camshaft up in a block with a degree wheel to determine duration.
OR,.......you can find a race shop that has a Cam-Doctor. :tup:
TYTILIDIE
METH HEAD
Re: Cam I.D help
Yeah we ended up getting the gross lift. I did not end up degreeing the cam though. Kind of wish I did but didn't think it would kill me to skip it. That and at the time I didn't want to fork out the cash for the wheel. Im sure it will work just fine.
Ry368
Re: Cam I.D help
Ohhhhh..oops...I didn't know he was asking about your cam? Is it still the KB or am I missing something here?
confused....?
TYTILIDIE
METH HEAD
Re: Cam I.D help
:rotf: He is asking about a cam that was in his Syclone. The KB I was using as a comparison in the way that I went through something similar. :tup:
