i meant to say .645. what cam would you recommend?jwaller said:does the cam have a base circle lift of 654? if so then just multiply by the rocker #. but if that is advertised lift then you must divide by 1.5(thats what most companies use for advertised lift) and then multiply by the rocker ratio.
I think your talking about advertised lift bc otherwise you'd have
981 and 1013.7 and those are some insane unmbers that dont even make sence in BBC world till you go top fuel.
your last comment on 700 spring and 654 lift doesnt make much sence. you need the spring to have more lift than does the cam/rockers but you also need it to have the right spring rates. something hard on cams with the heavier springs.
