Cam Opinion
proptop
Not an expert here but I think that we would need to know more about the build (turbo size and Generation). Intended use of truck race/street, motor size/stroke. Head type and any work that has been done to them. I went and looked it up on the link and my thoughts is that it is a bit big for a daily driver (224@50) might be a little rowdy on idle also might bleed the vacuum down a bit. I had a cam a few years ago similar to this but it was a bit smaller 210/210 112 and it made 19" of vacuum in park and about 17" in gear in a 265 ci motor. Might have been a bit small but it made a ton of torque and torque is what moves the trucks.
Bob
proptop
Sir,
I contacted a well known member on the Turbo Buick site and awaiting his recommendation. I also included my cam sheet that is in my current motor. Side not the cam blank is for an old style cam nose so it won't work in a production roller block.
Bob
wildphil
I Love My Ty's
proptop;n1862819 said:
Sir,
Bob
Those specs are close to the cam I had made for one of my trucks.
proptop
Wow,
That is really close and I would bet that you could throw a blanket over both of them and they would idle very similar and make about the same amount of vacuum/power. These v6 motors don't need a lot of cam. The bigger the cam the harder you have to turn it. In addition you have to have a bigger convertor to get them to spool up on the street. Next time/cam I might narrow the lobe separation a little not sure yet.
Bob
proptop
Not sure how yours ran but I am still trying to work the bugs out of mine currently.
Bob
IGottaSy
Comp cams 19-118-4 claimed to add over 40hp alone. This bad boy works from 800- 4800 rpm which means higher stall not mandatory. Also, no need to re work heads for higher lift? Well, they also mention roller rockers with pushrods to fit. Don't go too stiff with the valves springs. Should be100 lbs seat pressure but someone correct me if I'm wrong.
I have a similar cam to that in my Syclone, except with 214/214 duration instead of 218/218. Mine idles well at 700rpm and I am happy with it but I may be tempted to do with 218/218 lobes like you have.
The Comp Cam 09-430-8 cam seems like NA cam.
DaveP's Ghost
Well-known member
I have a custom ground cam by RPM, Dur @ .050 224int 230exh 115 LSA
From my recollections when we were building Matt Q's engine, and I took a WAG and had a custom cam done for DesertSy, 114/115 is about right in a street SyTy.
The secret is LSA. Turbo motors want wider LSA to avoid reverse pumping or exhaust dilution of the chamber during overlap. Boosted engines do not need or benefit from overlap or short LSA. Another aspect of "new think" regarding turbo engines is to make intake duration longer than exhaust duration. The exact opposite of what is done on NA engines.
Every book I've read about cams in NA engines states "the most important valve timing event is Intake Closing". It still is. But in a Turbo motor, you don't have to open the Intake as early or with as much overlap to get good cyl-filling. I've seen some turbo cams that have NO overlap. Turbo engines don't need or want overlap.
