cam with pontiac heads
sean
what cam are you running with the pontiac heads and turbo? can you you use this set up on the street? i'm not worried about the emmisions
nightdiver
Re: cam with pontiac heads
I used the 422 with good results. I also got a custom that is going in as soon as i get the new timing gears. For the tt stroker i got a solid though.
If you want it for the street get a hydro cam so you dont have to adjust the valves all the time
I use a 3200 stall TC
sean
what pontaic are you using 8 or 10? how many psi where pumping into the motor with the 422 cam?also what tranny are you using?
ed hess
race or get outta the way
ponti heads with solid roller, offset lifters, offset jesels, and thm 400 trans.
emmisions! roflamo :)
how does 720 psi over nose and 350 on seat sound for spring pressures. lol :) should be able to wing it over 8k rpm without floating. :)
drive on the street. yeah right.
but i can teel you one thing.
it sure is nice to be able to adjust valves without having to worry if you have to much preload on a lifter plunger. and with the jesels you can remove them and you dont have to readjust valves each time. but i numbered every thing in the valve train with an etcher.
nightdiver
I got the 23* heads and ive been up to 29 psi easily. I think its easy to go up to 35 psi but i dont know how the crankshaft will take it :)
I didnt use the solid cause its 292* adv. and there is less dynamic compression to spin the turbo(s). The stroker i build with 300cui can handle this loss at low rpm better. Now was i wrong to build it with 8.20 compression or what ? A 9.5:1 would be a lot better for the combo in order to spin the turbo sooner and easier and all i had to do is lower the advance at the top of the map.
The custom hydro cam i got comes from Mike Lee but the company sent an old style cam with different sproket and we have to install the othe kind of timing set. Its 276/276 with .51 lift if i remember right
I use a 700r4 build by me with parts and step by step directions from George Blake.A lot of work in there specially with the 3-4s that are custom bronge. I got a billet TC from Nolan with 3200 stall
I was ready to go Eds way with the 400 when Blake said that would make a tranny for me
nightdiver
I never went to the dyno, but i will soon. The block is stock with milodons and studs
sean
nightdiver do you have the part # on the stuff you used on the heads? i'm going to do the same set up if you don't mind
100in6
100in6
if you build a motor with that much potential power you will be better off with either a 400 transmission or if you want it for street driving go with a 4L80. they are both basically the same trans except the 4L has a 4th gear overdrive for street use. not a bad idea if you can to change the gearing to a 3.08 front and back. thats the only gear other than the stock that you can go with in the front end. one main reason is, that if you intend to race, both these transmissions have a taller 1st gear and will have better launch characteristics and times. they are also both quite a bit stronger, and can be built to be monstrously stronger. you can throw all the money you want to at a 700, but it will never be as strong as the 400 types. if you want strength and also faster launch times go with the big one. the 700 has a lower first gear and shifts out of first very fast and is harder on the drivetrain also. it will take some work to fit a 400 family of trans, but if you want i can tell you how and where to get all the parts. the only weak link is the shaft that goes into the transfer case which has to be smaller than what would be the normal 400. i'm not dissing the 700's but if your gonna go with brodix big valve heads and intake plus the turbo and cam to make it all worthwhile you should go with a 400 family trans.
i had a 700 in my almost 10 flat sy with the stroker motor, and you can not launch them as hard as the big transmissions. you can get a 400 with a manual valve body that you can shift as needed. no matter what you do, you'll never be able to make a 700 or 4L60 as strong as the bigboys. it's just a matter of size and strengh. look at what the other guys that are really running fast. hoover has a manual 400, ed hess has a 400 (which i got for him) robert in sweden is running a 4L80, the ty i helped build for the guys in poland that is now running almost 10 flat is running a 400 (which i also got for them). i know a little about what i'm talking about here. listen or ignore, but the 700 with it's lower first gear and smaller size is not as strong or fast on a high torque high horsepower sy. i know phillip is running a 700 with success so don't tell me the exceptions. play the odds and the 700 will not hold up as long. ask the guys who are running the 400's because they all learned.
ed hess
les is correct
if you do the 400 swap i wrote a how to in the tech section for particulars.
but more on the pontiac heads.
theres 2 versions.
one starts out with a 78 cc chamber.
to get compression where you want it youll need to do some work on them.
possibly angle milling the decks, porting, milling for spring seat height. porting, clearancing for the washers under the heads stud nuts to fit due to the angle milling changing the geometry.
You will also need jesel offset rockers, and also offset lifters. if you go with a solid roller and high spring pressures you'll also need 3/8 or 7/16 dia pushrods.
even if you used 5/16 pushrods you will need most likely to clearance the heads around the top of the rail for the roocker cover seal or else the pushrods will rub the head. Lots of work to make the pontiacs fit.
Then your going to need something for an intake.
Then when you want to make max power on the pontiacs you'll see that welding up the exhaust ports and raising the same port to make better velocity on the exhaust port and your going to need custom headers.
Just a matter of how fast you want to go (read that as how much you want to spend)
Unfortunately its not just a matter of finding & buying parts and bolting them on.
On the brighter side...
I can tell you 1203 felpro gaskets can easily be modified to work with pontiac raised runner heads quite easily. <--- big deal after reading all the stuff above. :)
and one thing i forgot... with those jesels you can count on making your own rocker covers.
ed
canadian
sy in progress
ed hess said:
theres 2 versions. one starts out with a 78 cc chamber.
any part numbers? mine are stuck behind a bunch of crap in the garage. not really motivated to go and dig them out to see what they are. i *think* they're 449 heads.
at 78cc's isn't that kinda big? i thought they were less than that (guess it depends on the p/n). you might be able to get away with the compression you want using the right piston. if not, you can always play around with cam timing to bleed off pressure.
picked those up a while ago, although they do need to be checked since the rockers look like they have some "clearancing" on them. don't have the lifters yet though.
i'd recommend upgrading the pushrods no matter what. even though these aren't high revving engines, i think good pushrods are worth it.
yup, nobody said it would be easy.
have a pontiac/brodix carby intake that would need to be modified to use fuel injection
don't you need custom headers anyhow? can't use the stock syty one's on pontiacs
have a set of covers that came with them. includes nifty oil passages as well to keep 'em lubed up.
ed hess
yep same 449 casting, if you have 2 valves for them you might want to cc them.
the clearancing on the intake rockers will be needed also depending on what spring dia you have. you'll need to check with the springs for the intake rotated so that the flat of the spring end is under the rocker. if the spring is tured so the end isnt under the rocker you will miss seeing the clearance need. of course this is proably dependant on spring pressures and diameters. but we got some pretty big springs in there with del west (something like that) hardware holding them in place.
canadian
sy in progress
was 78cc's a typo? seems odd that they're that big. i would have thought they'd be smaller. at that size you might not need dished pistons to reach the compression ratio you're looking for.
haven't gotten far enough into them to even need any of that stuff yet. saving for the kid's college fund! LOL. i basically have a set of bare heads right now with seats installed and helicoils in all the right places. other than that they are factory fresh. intake hasn't been used either. i don't plan on running 8's (unless a sack of cash falls into my lap), so i doubt i'll need any killer valvesprings, etc.
for now, i'm just gathering information and maybe one day these things will be bolted to something other than a shelf in the garage.
nightdiver
You got PM also.
Ed , thats very well writen. I had to do a lot to make it work. I think i got to write the article for the 23* top end. During mock up you got to be sure that the pushrod doesnt touch the head. In my case two of them were in contact aand i couls hear a ticking noise . That left a small mark on the head and i was able to grind that little spot with heads out ofcourse
Also Les is right. I took my best shot with the 700 cause there was no bolt on 4l80e kit by that time and i like the OD. We (Blake and i) did our best to make the 700 handle the torque till a problematic tc made the tranny loose pressure and burn the 3-4s . We can only assume that the oil cooler was full of shit and made the tc get severe balooned.
After this the tranny holded all that tuning up to 22 psi and after the meth kit install up to 29 psi.
A few 10.20 runs and many street races and it shifts the same way like the first day.
I dont recoment someone to do an extreme 700r4 like i did cause there are too many things involved and i think its almost impossible to find a tranny builder that is ready to spend so much time to do just a tranny. Hell yeah i spend 320 euros for the custom 3-4s although master said that i dont need em.
So now the solution is ready and bolt on. 4L80e
Now if you want to make your engine last longet just add two more cylinders. If i could change the stroker bowtie with a V8 i would do in a sec......and dont start with me V6 lovers :)
100in6
100in6
3rd gear is one of the most common failures on the 700. my 700 i had in my sy is still going strong, but to make one strong enough to take big power is still a crap shoot. and doing it is an expensive 700... a mid level 400 will take tons more power than a top level 700. i'm not saying everyone needs to change to a 400 family trans. put for big power the strength and higher first gear is a better way of going. and dollar for dollar, to build a herculean 700 costs in the same neighborhood as doing the conversion. i know guys who have bought stock 4L80 transmissions out of a junkyard and stuck em straight in cars and they work great great. and now that the parts are available to convert them into a syty i think it's a viable change.
the peace of mind alone knowing your trans isn't gonna go away if you beat on it is worth a few bucks by itself. :) i'm sure if the 4L had been available back when syty's were built it would have been the stock one. i'm not spoutin theory here, just experience and knowledge of what can be done if someone is so inclined. for a general trans the 700 does a fine job. but if you want to run in the low 10's or faster i think it's a better choice. especially now that there are guys out here that know how to do it and what parts you need to accomplish it. kinda funny how some guys are willing to throw money at the engine like mad, but don't want to do the drivetrain to hold it...
ed hess
no it wasnt a typo.
best advice is to cc the heads before you do anything (read as spend any money on them)
poor old sean is reading this and by now he is saying...screw this crap i'm sellin these heads on ebay. lol :D
ed
