Cam????
typhoon x
Anybody know what cam this is? This is all number i can find on it. Gm Pt Bc 8 065 thanks. Specs if posible.
DULM
Re: Cam????
If that's a GM cam, and you got the P/N from between the last lobe and the distributor gear, it should be a balance shaft cam.
typhoon x
Re: Cam????
It is a gm cam and yes that Where i got numbers. U got any specs on it????? Ive looked till im blue in the face. LOL.
Re: Cam????
intake-.432
exh.-.441
208 dur.@050
Are you going by the numbers stamped on his cam?
Not all balance shaft motor had the aggressive SoGt cam in them. It depends on if its a vin z or w motor. The SoGt cam is actually a really good cam for being stock.
Icarus-54
Donating Old Member
Re: Cam????
All cpi motors used this cam from 92-95.Most blazers had that engine.I guessing his was a w.If I can find it I have one laying around somewhere.
typhoon x
Re: Cam????
I was hopeing it was the hot cam with but i could find anything to match specs too. How do u know if thats it by the numbers i got? And thinks for the in put.
Re: Cam????
Look at the vin of the truck it came out of. W in the 8th digit is the cam specs above.
