So I got a new camshaft and I an getting ready to install it in the next week or so. I have new lifters and push rods. Is there anything else that I should look into before doing the install?
Timing Cover Set - JV1041 - $7.99
Intake Set - MS16154 - $39.99
TB Gasket - 10105351 - $3.99
Water Pump Gaskets - $0.99
Cap & Rotor while you have the dist out?
Thermostat & Gasket while you have the lower intake off?
Serpentine Belt while it's off?
Upper/Lower Radiator Hoses while their off?
I should have all the gaskets ready, I was really worried about the mechaical components. The engine has about 140,000 miles on it so I was looking for possible things that I might need to replace depending on how the wear looks on them. If I have to replace anything on the heads, such as valve springs or rockers, I will just go for new L35s if that tends to be the case.
Fortunately, our engines aren't very hard on valvetrain components, so I'd say no. Unless something is visibly damaged, weak-looking, or broken, leave it. Almost anything other than lifters, pushrods, and rockers require special tools and/or or head removal to replace anyways (including guides, seals, valves, seats, locks, and springs.)
If it has the stock short block (mainly piston/rods), I wouldn't put a cam in your motor. Our engine components don't like to rev, keeping the RPM low helps keep the engine internal together in one piece. When the list archives were still up, I read about quite a few poeple blew their motor by swapping in a cam, that allow the engine to rev to 5500 rpm.
