camshaft question
W
wayne74447
Guest
i am looking at this cam, i am wonsdering if it is too much cam for a turbo?
Lobe center 108 degrees
advertised duration intake:280 Exh:288
Duration @.050 intake:226 Exh:232
Lift Intake:.474 Exh.484
I am not one on cams, but my buddy runs this cam in his NA 4.3 and it hauls, i know it is a bit wild but would it work for a turbo app??
wayne
nightdiver
Not good for you ...too much overlap , late boost ,less vacuum
If you want a cam pick one with max lift and a bit milder degrees
Dont forget its all about the combination though
ghettosled
SYTY SUPERSTORE
Depends on your motor combo, and hp goals are but the lobe center would be way low for a turbo motor. Try around 112 or higher. ALso your EMS or chip will determine what limitations you have.
