Can anybody help me
johne30m3
Junior Member
My slcone has started cutting out when I accelerate very hard. For example: from a deadstop around 40 to 50 MPS then at 70,80,90 etc. I would say it cuts out for 1/2 second and then starts accelerating hard again before it cuts out again. I havent noticed any knooking or pinging. Once in awhile it has backfired at very low rpm. I just purchased the truck and to my knowledge the only modifications are rebuilt motor .030 over ad Kenne bell cold air intake and red hot wires. I recentely changed plugs CR42TS, cap + rotor fuel filter and put in a Walbro 255 fuel pump and adjustible fuel pressure regulator. I've heard of overboost and have also changed the boost solenoid and all vas lines seem to be good. I had one cracked rubber elbow on the boost solenoid I changed it. hte other two seemed to be a little worn and loose but not cracked. Should I changed them. I would also like to know if the wastegate creates overboost? I live in the northweast and its been 0 to 20 F for a couple of weeks now. Also I tried to get codes from the diagonostic port and the check engine light does not flash it just stays lit. When my truck cuts out the check engine light doesnt flash like I heard in a case of over boost . thanks
sounds like overboost or reeeeeal bad knock retard. first thing to do is get data master to see what is going on. do you have an after market boost gauge?if so what does it read.
Tooky
Serious about performance
Also do you always keep more than 3/8 of fuel in the tank? With less than that, the pump will starve and the truck will stutter on hard accel.
syclonekid43
welcome to syty. where abouts in ct are you. up untill i never saw another sy in ct. it about time. as far as your problem. to me it sounjds like the fuel pump is shuting down on you because of over boost. do you have an aftermarket boost gauge in there or the stock one. they say the stock boost gauge sucks. also if you have the factory chip in there it only lets the fuel pump work up untill 14.5 psi of boost. you might want to try to adjust the wastegate rod. i would open up the computer in there and make sure you dont have a hyper tech chip in there. i made that mistake when i bought my sy. i never looked inside my computer. and it ended up being a hyper tech chip in there and it cost me a motor due to overboost. send me a pm maybe we can meet up if your not that far.
smeagol
overboost in the stock chip doesn't turn the fuel pump off, it cuts the injector pulsewidth to zero, FWIW.
I'd take it easy on the truck until you get a scan tool, maybe adjust the wastegate rod.
