Can anyone "Name that Injector"?
Sy Guy 0024
I'm still trying to sort out all the mods done to my truck by the previous owner. It **supposedly** has 36lbers in it, but I'm pretty skeptical after some of the discoveries I've made lately. Can anybody ID the injectors based on this info: Injectors are red-topped with part no 280150756 stamped on them? Thanks.
Corbin
Sy Guy 0024
Hmm, that's what I was afraid of. Put that up there with the alleged "ATR exhaust" that, upon closer inspection, revealed a "magnaflow" stamp on it and the 7th injector system that I discovered to be disconnected. Wonder what I'll find next on this truck? I need to id my turbo next....guess I didn't give the truck a thorough enough once-over that I thought I did prior to purchase. :-?
Thanks for the info, guys.
Hu Ryde
Your bringing it to the meet right? If so I'll help ya get it all figured out. My opinion on the 7th injector, pitch it. Later.
Sy Guy 0024
Ha Jesse! I knew you guys would tell me to toss the 7th injector! :)
Personally, I don't see how it could work well. I was going to install the TB air foil today (which the previous owner told me was already installed and was throwing in an extra one w/the truck) so I had the 7th off. The 7th injector squirts into a small hole that leads to a channel on the supplied TB plate. From here, I guess the fuel runs through the channel, then drips into the TB where it is supposed to mix w/incoming air. Just doesn't look like it could work that well as the fuel would not be atomized like it is straight from the injector. (By the way, the air foil would interfere with the 7th injector, so the two cannot be used together). I was gonna ask for opinions on this part at the ohio gathering, but you beat me to it. :D
I have lots more questions to throw at the OH-KY-IN guys, so be prepared to have your brains picked on Sunday! See you then.
Corbin
