can i usebalance shaft block
10secTy
Sy-Ty builder and Tuner
Re: can i usebalance shaft block
syclone0209 said:
Are the later model balance shaft blocks strong enough to use for our applications?
The 92-95 blocks are weaker due to the material removed from the bulk heads. On the 96 up vortec blocks there was more material removed around the bottom of the cly bores.
Stay with the non balance shaft block if you want the strongest stock block.
Nolan
nallj92
Im running a 92 balance shaft block now, its been working good for me flogging 22 lbs at it.
jwaller
Evil Genius/SyTy Guru
I've used several of the early 92-95 bal blocks and they have done fine, but if you want the strongest possible production blocks then stay with the early ones.
