can someone explain how this ultimate chip works?
spooldup
Super Member
What are the benefits from using it? How hard is it to use? How do you use it? Is it better than a pitbull? Anything i left out?
bdubb
I am teh kingpin!
hi and welcome to the site. you must be new and not read any of the 1000 topic posts on this chip. read threw and look its all there. not really that hard.
nick041881
well i guess i owe it too you after accidentally calling you an asshole! here goes:
the ultimate chip is a chip that runs off of a 3 bar map sensor.the stock chip and others(pitbull) run off the stock 2 bar setup. the difference is the 3 bars ability to read and properly fuel the truck for boost levels above 14.7 psi, which cannot be done on a 2 bar system.
the ultimate chip also has several different timing/boost settings allowing you to control timing advance and boost psi directly from your drivers seat. (not possible with any other chip)
the chip was developed by people who know their shit(brian green)and have done the testing possible to make these things work.
dont waste your money on any other chip.
there im done....i hope thats enough detail because im tired! if any of this is wrong, someone correct me....
peace,
nick
spooldup
Super Member
wow that was educational. Thanks for the info. But i am a little confused on how this would work with my setup. I have a bigger turbo so would i just leave the wastegate/bov alone?
SY732
Can you list all of your mods
spooldup
Super Member
mmm ok. If i can remeber the list.
t-66 turbo
3" dp
atr exhaust
walker 3" cat
pitbull
atr cold air kit
atr underdrive pulleys
atr aux intercooler
shurflo
atr wires
st swaybar
kyb monomax
2" drop
atr turbo to ic hose
atr gate
hks bov 16lbs pop off
afpr
tranny cooler
different things in the tranny, not really sure what they did
2800 stall converter
fuel pump
i think this is it so far, o and NOS.
Eluding
With airflow mods like you have it will be REAL easy to run lean on a ATR Pitbull chip and blow your engine. I think you need the #50/lb injector Ultimate chip.
And nitrous is just a realllly bad idea with a stock shortblock, IMHO.
JoeLutz
Get rid of the underdrive pulleys. They make your charging system weak and can turn the waterpump slower.
