Can we run without a Thermostat?
Syclone#1992
SyTy.net Moderator
I know it will take the truck longer to get warmed up, but it would make the truck run so much cooler. Do we really need the pressure a thermostat provides?
TIA
4C FED
Absolutum Dominium
There are some, as well as myself, who have used a 140 deg. stat.
You can get it from your local marine parts dealer.
ttdolson
Yep, ive got a 140 deg. in my ty.
I always get worried that i don't have enough temp in the motor.
I guess i'm worried about spinning a bearing / damaging the motor.
It's just as bad to have the engine too cold as it is to have it too hot....
ghettosled
SYTY SUPERSTORE
the key is having the oil warmed up, not so much the coolant temps. I ran/run a 140 and it works great. You could try running a restrictor plate so the water spends some time in the radiator and has a chance to cool off. Some times w/o a thermostat the water flows too quickly and doesnt cool off as well as having a 140 or a restrictor plate.
Tooky
Serious about performance
I think you're all nuts!! :lol: A friend of mine ran with no thermostat on his stock Syclone and he found out the chip doesn't lock the torque converter until 150*F. So you're running 140*F and the torque converter is never gonna lock. Heads like cool temps, piston rings like hot temps. The 160 is a little on the low side (accelerated piston ring wear, says some Turbo Dodge experts) but I think the reduction in overall temperature and lowered detonation makes it worth it. I don't know how you guys with the 140 do it..
On my truck if I don't let it warm up long enough in my driveway and I leave, I get onto the main road and I can feel the truck is riding high RPMs without even having to look at anything. I watch DataMaster in my passenger's seat and soon as the engine temp hits 149*F or higher, POOF the RPMs drop a couple hundred and the yellow "TCC Lock [0]" item on DataMaster becomes a [1].
One other thing I should mention. He installed the regular Ultimate Chip, and had the 160* stat by that point. One day he tried removing the thermostat and next time I saw him his truck was idling at 2000 RPM like it had a gigantic vacuum leak and the truck was driving like shit. It was so bad he had to go home. He checked everything and it wouldn't fix it. Finally Brian Green thought it was cause of the lack of thermostat and insufficient temperatures. My friend put the thermostat back in and Badda-Bing, Badda-Boom, his idle returned to normal. "True Story"...
myclone
I noticed the same thing on the TC not locking below ~150 deg. I thought my trans or 9/11 TC was dieing but thanks to Wallyworld (John Waller) we figured out what was going on. I was rolling down the freeway at ~70mph and noticed the RPMs were way up there by the tach/exh note. Hit the manual TC lock switch and they came down to normal. This was on a COLD (~40deg) day last winter when I needed a boost fix and got myclone outta the garage for a drive.
FWIW on the lower T stat if you have the stock chip.... Keep an eye on wheather the ECM goes into closed loop and stays there or not. Before I put the Ultimate in I tried a 160 t stat and myclone would go into closed loop only to drop right back into open loop again (according to the scan tool). I put a 180 in there and it would stay in closed loop fine. I posted a thread about this and some ppl said they had no probs with a stock chip and a lower t stat. I guess its like everything else with these trucks... Each one behaves different.
Running in open loop can over heat the cat due to the extra fuel and cause the innards to melt which plugs it up. Im sure eventually it will wash the rings out and contaminate the oil with fuel (that aint good). Prolly spool/run like you got a house tied to the rear bumper too.
HTH
warmpancakes
I had the same problem Myclone scared the hell out of me, thought it was gonna be time for a trans (had truck 3-4 months) ken
JustBeachin
Plays well with others
I ran a 160 until I needed to pass smog. Then I put the 195 back in. I noticed that my gas mileage went up. So I compromised and put a 180 back in it.
smeagol
Anyone got a source for the 140 deg thermostats?
I'm gonna call around local, but didn't have any luck last time around.
