cant connect to aldl
Slowcone
tried to log some data, 1st i tried to use tunerpro rt. i have never used it before. i downloaded all the xdf and ads files along with a bin that was close to mine. i was trying to get familiar with the program since my ostrich is on the way. anyway, i could not get it to connect to the ecu. i keep gettin a message cannot initiate com port. i have gone into the device manager and played with everything from com1-com10 and nothing.
then for poops and giggles and tried to connect via datamaster and same deal, could not connect to ecu. it says my adapter is ok but cant connect to the truck.
i have used datamaster on this truck before with the existing cable....tried all the wiggles and handshakes and could not get it to go. prior to this i have removed the stock chip and reinstalled it. i cannot recall if i logged after that since its been some time since i last ran the truck. is it possible that the chip is not fully seated? even though the truck runs fine?
nello
Re: cant connect to aldl
Not sure how much you know about computers but i would check device manager in windows first followed by choosing the correct com ports in DM...like com3 or com4.
Tooky
Serious about performance
I have some tips on connecting DataMaster to your laptop, on my website under "How to get your stock truck Deep in the 13s".
If that don't help maybe try a borrowed laptop just to rule the COM settings out?
willyson
trollin'
have you switched USB ports? If you install the driver on one port with the cd and connect it to another USB, it will not recognize the ALDL cable
