cant get a steady fuel pressure
elorejas
Ok I just installed in december a new accufab fpr, walboro pump i set the psi at 43 with vac off drive it a while park it them check it again and either it goes higher or it lower next time I check. I did install the fuel pump relay kit aswell anythoughts. And because of this I can tune the truck with the turbo tweak chip because it keeps moving the fuel pressure and once I get no knock it comes back when the psi changes.
Quickstop [UK]
Combating adversyty.
Re: cant get a steady fuel pressure
Sounds like your AFPR is wack.
Did you tighten the screw on the AFPR so the pressure doesn't vary?
elorejas
Yeah I tightened the nut on it so it wouldn't move but it stills keep on moving around. Then I re adjust it and later on its at another psi. I'm tired of dialing the chip everytime I try to drive it
Quickstop [UK]
I would change the AFPR out. Don't waste time trying to tune it if it's fluctuating like that.
It changes at idle right? It's designed to vary while you're driving :D
elorejas
It changes at idle I set it and drive it later on I re check it and its set at a diffrent psi
Logan
I would second Quickstop's guess. For a manually adjusted part to physically change like that there is a flaw in it. Change it out and I would bet the troubles will go away.
