Can't get Ty to run correctly???
ThaJokr
Super Member
Posting this for a buddy since the registration is closed right now:
I cannot get the truck to run right at all. It detonates like no other as soon as it hits 3-5 psi, so I checked the timing, it turns out that it was way advanced by like 30*+ so I pulled the timing back to 0* and it now wont idle at all.
Flyin Ryan
hated cuz he drives fords
Re: Can't get Ty to run correctly???
I would yank the timing advance wire that Dave asked about above, verify top dead center and set timing to zero and see how it starts then. I say verify tdc because it's not common for a stock balancer to spin due to age and wear.
wildphil
I Love My Ty's
Yes, hopefully the balancer ring has not spun. A few weeks ago I thought the timing was off on my truck. The mark was no were near 0 deg. So I tried to set the timing and couldn't get the truck to run with the mark on 0 deg. Ended up having to install a new balancer. So the timing could be set correctly.
Keep this in mind to check for if you can't get the truck to run correctly after setting the timing as others have posted.
