can't hold truck for launch
LawnGnome92
I was going about 90 and stopped pretty hard now my brakes won't hold the truck for a launch i can only get to about 2000 rpm then it starts to move before i could hold it to about 3000.
The truck is bone stock and when i stopped i could smell burnt brakes.
Luke
Fish sticks SUCK !!!
Re: can't hold truck for launch
glazed pads, got spotted rotors and drums would be my guess
Ry368
one mile = 5280 feet
Does your pedal slowly drift toward the floor when at a stop light? If so it kinda sounds like my new truck was acting before the abs light came on because it failed.
sly dvl
Ya, it's got a Turbo
Is the pedal spongy now? Try bleeding them.
Other then that it sound like you glazed everything.
LawnGnome92
it stops just the same the pedal is not spongy and the rotors and drums look good just like they did before i did that is it possible that just the pads are glazed?? one of the front ones squealed real bad after but it stopped after about 10 miles
LawnGnome92
I have an extra set of drums for my 92 2wd Sonoma I put it on to see if it would go one but i didn't run it that way is it okay to use those to see if it helps anything. The drums fit on it but i dunno if i should try it or not.
Tooky
Serious about performance
Pull off a wheel and give it a good inspection to see what's up (if anything).
dutchty
With stock rotors? then it must be glazed pads after very hard braking
Tyes93TY
Could've boiled your brake fluid. I would start there, flush the system and reservice with fresh fluid. If that doesn't work then check the pad for glazing.
