cvcsmkr
mods:
rebuilt motor with typ aftermarket parts, 15k miles ago
kb a2a, kb TC, pte44(rebuilt few months ago by very good shop), walbro FP, 50#ers, ostrich, LC-1, pte downpipe, txs bov, fuel press 42psi, 3" exhaust all the way back to magnaflow muffler
i was making 18+ psi 2 weeks ago.
found the TB shaft was leaking, and a few other vac leaks, with bicycle tube trick the intake would hardly hold 1 psi w/air compressor.
now: had tb rebuilt & bored, re-did vac lines, now intake will hold 5psi w/air compressor (bicycle tube is about to explode)
there is no intake on turbo, no boost controller, wg actuator is open to atmosphere, no play in turbo shaft, no oil in compressor housing or downpipe, i have not heard any exhaust leaks, boost comes on a lot faster just wont go past 15.
****fixed***
sure enough the BOV was leaking.
i had it plugged into vac source after check valve.
weird it was holding 18psi fine 2 weeks ago, and now it wouldnt hold 15.
truck is running great now.
****fixed***
