Can't read codes or data stream!
James Thomas
"NO CLASS"
Ok, here's one I haven't run into before. I can jumper the A.L.D.L. connector and flash the codes, cycle the solenoids e.t.c. and self diag. seems to work fine and the truck runs good too. When I hook up my O.T.C. scanner I can't read codes, data stream or data log and get connection errors. In my experience with GM E.C.U.'s (which is quite limited) if the E.C.M. and self test / diag. is bad then the truck runs bad too or not at all. Any one have this problem or got any info???
_______________
James Thomas
leroy
Re: Can't read codes or data stream!
I've seen the terminals in the ALDL connector get loose. You could connect your scantool to the wires or the pins at the ecm to test. You only need pin A, and M to test. A is upper right. M is lower right. A is a ground. M is pin A9 on the ecm (orange wire).
Jim
Sy#2373
I used a friends OTC scanner once and had the same problem.
He has two cables for the scanner, one worked the other would not.
I have no idea what if any differences there was between the two.
Loeryder
We have a very "noisy" ecm.
It likes to talk a lot and listen very little.
Kinda like a woman.
James Thomas
"NO CLASS"
Yes I thought of this before I posted. I have two scanners, one new Nemisis and one old Pathfinder. No reading on either of them with two different cables.
_________________
James Thomas
AUSyTyIN
Unbusted $#it box
Kinda like a woman.
So if you hit it hard enough, it will behave? :rotf:
jjorgensen52
NHSTE - I'm the only one!
No, that'll make it all sulky :lol: .... it'll need something shiny and expensive to cooperate ... say, new turbo :tup: ?
AUSyTyIN
Unbusted $#it box
Turbos create pressure, the pressure blows air into the motor, so there for you buy a new turbo, you get a blow job, right? :tup:
jjorgensen52
If you wanted one from the ECM :screwy: :rotf:
Bill Z
Back to James’ original question.
I’ve noticed that many of the generic cables to ECM don’t include pin M. The 3rd gen camero uses a different pin (I think ‘H’). If you notice pin ‘H’ isn’t used on a Typhoon. I had one of those cables with the smart looking connector that fit over the whole ECM connector. It sucked because you couldn’t tell what pin it was reading. What I had to do to get one of the other cables to work was to install a wire from ‘M’ to ‘H’ where both world work.
That worked with the cable I use to use.
Good luck.
jjorgensen52
Good luck.
So couldn't you just pop the M pin out and move it to H? Sorry bout that, 16sy16 and I have been hijacking threads all day :roll:
Bill Z
You could but then when you get a cable built for the TY you might have forgotten. This way, both ways work. Also, At the time, I couldn't tell you where I would be to work on the truck. One guy had one set of cables and another guy had a dif.
This way, it all worked out.
jjorgensen52
good call
James Thomas
"NO CLASS"
I been tracing ALDL wires and going ape shit over wiring diagrams. I got a 93' set of factory manuals but it don't match my 92' wiring? Any body got a 92' diagram from ALDL to E.C.M. and or the ALDL & ECM pin outs? I may have a very rare type of failure (truck runs fine but no data out put) which means the ECM or PROM are bad but I really hate to wast a never opened, still with the seal ECM to find out.
Thanks for the info!
____________________
James Thomas
jjorgensen52
James Thomas
Here's most of the wiring in PDF form... has SyTy and SGT, I think it has both years.
http://www.syty.huryde.com/wp-content/uploads/2005/12/Wiring Diagram.pdf
