James Thomas
"NO CLASS"
Ok, here's one I haven't run into before. I can jumper the A.L.D.L. connector and flash the codes, cycle the solenoids e.t.c. and self diag. seems to work fine and the truck runs good too. When I hook up my O.T.C. scanner I can't read codes, data stream or data log and get connection errors. In my experience with GM E.C.U.'s (which is quite limited) if the E.C.M. and self test / diag. is bad then the truck runs bad too or not at all. Any one have this problem or got any info???
_______________
James Thomas
_______________
James Thomas
